1992 350L Trailboss 4x4
Old Apr 8, 2008 | 01:50 AM
Wireman001's Avatar
Default 1992 350L Trailboss 4x4
Hi I'm just new to the forums here and it looks like their is a lot of good info here. My question is as follows:
I have a 92 Trailboss with a 350L, I was wondering if anyone has tried to do a 4 stroke engine swap in these machines. I love the bike, It's in great shape, but I think the 2 stroke is getting a little weak in the bottom end, but rather than junk the machine I was thinking of putting a 500 4stroke in the old girl. Am I wasting my time?
Old Apr 8, 2008 | 09:37 AM
Ujoint's Avatar
The 2 stroke 350 and 400 engines are basically the same engine. Other than the bore, Very few differences physically. The 4 stroke 425 and 500 engines are basically the same engine.
Looking at the model ID numbers for a 2 stroke 400 and a 4 stroke 425, they use the same frame ID. Theoretically this should work.
Now, this being said, there is a lot more to swapping to a different engine - Frame mounted electronics specific to the engine and the exhaust system will be a couple of obvious changes.....
In my opinion, if you have purchased all these parts to change to a different engine, you have basically paid for a complete used quad, especially if you consider your time and labor in making the swap happen, and then any unforeseen frame differences that may pop up.
I would recommend just rebuilding the 350 engine from the bottom up.
Old Apr 8, 2008 | 12:37 PM
Wireman001's Avatar
No I havn't bought anything to do a swap I was just wondering if anyone had tried and what the difficulty level would be like. Point well taken, your buying all the stuff to do it you might as well just buy and use the other bike.
The 350 still runs good and has good compression, but is a little noisy in the bottom end. Are these engines typically terrible for fuel consuption? I'm only getting about 40KM to a tank of fuel. I am having trouble with it over fueling a bit, any insight on these engines would be great
thanks
Old Apr 8, 2008 | 05:11 PM
drlang's Avatar
Your lower end noise is probably primary clutch buttons. IMO. Rebuild that 350, unless you really like the work. Doc
68_327_c20
Nov 25, 2023 12:26 PM
cornermike
Aug 10, 2016 06:47 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
