Raptor 660 has no power
Got a 03 Raptor 660 and for some reason when i give it full throttle it sounds like there is a reve limiter engaging. I have rejeted, replaced the carb and airbox boots, readjusted the values, checked the choke and put a new plug in.. Any ideas.......
G
G
Gnut32,
Maddog is right. I had the same problem before. Have you put a new clutch cable or E brake block off on lately? In your clutch assembly/ E brake, there a button up there there. It's part of the "Safety Figure" of this Quad. If the E Brake is engaged the rev limit will kick in. So get a scew drive and push in that button in the assembly. You'll see that's your problem. Hope this ya. Take Care and Ride Hard!
The E Brake assembly I think is your problem. Go up in assemby and find that button. You'll see it. Reinstall the assembly but not the brake handle. Try that. Should be a little bolt or screw to remove the handle. Hope this helps. Take Care and Ride Hard!
