Raptor 660 has no power
Old Apr 8, 2008 | 07:30 PM
Gnut32's Avatar
Default Raptor 660 has no power
Got a 03 Raptor 660 and for some reason when i give it full throttle it sounds like there is a reve limiter engaging. I have rejeted, replaced the carb and airbox boots, readjusted the values, checked the choke and put a new plug in.. Any ideas.......
G
Old Apr 8, 2008 | 07:51 PM
maddog56's Avatar
Search "parking brake limiter" and/or "reverse limiter"
You likely need to adjust your parking brake.
Old Apr 9, 2008 | 12:02 AM
Yammer rider's Avatar
Sounds like a jetting issue maybe getting to much fuel?
Old Apr 9, 2008 | 05:16 AM
raptor010's Avatar
Gnut32,
Maddog is right. I had the same problem before. Have you put a new clutch cable or E brake block off on lately? In your clutch assembly/ E brake, there a button up there there. It's part of the "Safety Figure" of this Quad. If the E Brake is engaged the rev limit will kick in. So get a scew drive and push in that button in the assembly. You'll see that's your problem. Hope this ya. Take Care and Ride Hard!
Old Apr 9, 2008 | 10:14 AM
Gnut32's Avatar
No the cables are all stock. The e brake assembly and cable have been removed. Could it still be engaged without the cable still installed.
G
Old Apr 9, 2008 | 12:21 PM
raptor010's Avatar
The E Brake assembly I think is your problem. Go up in assemby and find that button. You'll see it. Reinstall the assembly but not the brake handle. Try that. Should be a little bolt or screw to remove the handle. Hope this helps. Take Care and Ride Hard!
Old Apr 9, 2008 | 03:58 PM
Gnut32's Avatar
do not have the E brake assembly. The assembly for the e brake has been removed.....
G
Firefighter400
Oct 8, 2022 06:38 PM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
