steel rims + 22,20" tires to aluminum rims + 20,18" tires
Old Apr 8, 2008 | 09:52 PM
crazy1291's Avatar
Default steel rims + 22,20" tires to aluminum rims + 20,18" tires
Approximately how much weight would be saved by going from 10" or 11" steel rims in the front with 22x11-7 tires to 10" aluminum with 18x6-10 tires?
How much weight would be saved in the rear by going from 9" steel rims with 20x11-9 rims to 8" aluminum rims with 18x10-8 tires?
all tires are 4 ply. The aluminum rims are spun aluminum.
Would 10lbs in the front and 12lbs in the back be reasonable? (I think the back would lose a bit more due to a MUCH wider rim.)
Old Apr 10, 2008 | 04:59 PM
crazy1291's Avatar
oh, come on! nobody knows what kind of weight savings i can expect?
What do you people think? 5lbs? 10lbs, 15lbs, 20lbs, 25lbs, 30lbs?
The kymco mongoose 250 is almost the exact same machine except that it has aluminum rims already and it weights over 30lbs less. Can I expect to loose about 30lbs?
Valder
Nov 28, 2020 07:38 AM
Honski250r
Sep 26, 2015 09:40 PM
01ssls1
Sep 22, 2015 06:50 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
Jason Campbell
Sep 7, 2015 02:25 PM
