2001 sportsman90
Old Apr 12, 2008 | 02:13 PM
razmataz's Avatar
Default 2001 sportsman90
looking at a used 2001 sportsman 90 with what the owner says it needs a coil. is there a coil on a 2001 or would it be the cdi box? any help would be great!
thanks.
Old Apr 15, 2008 | 06:28 PM
SRD93PGT's Avatar
To answer your question about the coil yes there is a coil on it. But to answer the question on which one it is i have to know what it is doing wrong. I can assume that you are not getting any spark. But that can also be the stator which is somewhat common problem. You will have to check the coil and stator with a multimeter and get some ohm readings. Let me know if you need more info or if they helps you.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
