360 air system/fluid help
Old Apr 12, 2008 | 03:10 PM
Dustinwe's Avatar
Default 360 air system/fluid help
I'm a first time ATV ownwer and have a 2007 Prairie 360. I recently noticed that there is a pink fluid in my air system. The filter is wet and there is a collection of the fluid in the bottom of the case. Any suggestions?
Old Apr 13, 2008 | 12:29 AM
harry1's Avatar
There is a rubber clear plug seen from the outside rear of the machine. You'll be looking at the bottom outside of the air box. This is going to look like a half ball of clear plastic about 1" diameter. You pull this off watching not to lose the spring clip that holds it firm. This is your air box drain port. If I recall my machine also only had a bit of this red lubricate I believe and I washed it away. Follow the cleaning instructions for your airfilter while your at it.
Dave
