05'400ex
Old Apr 13, 2008 | 02:44 PM
sdm111's Avatar
2 strokes or 4
Default 05'400ex
Im almost certain but I'll ask just to make sure. Does the engine oil also lube the tranny. So there is no seperate tranny lube that needs to be changed. Asking cause my bike can be real hard to shift, drove my friend's raptor 700r the other day and you can't feel his shift.
Old Apr 13, 2008 | 04:18 PM
99_400EX's Avatar
Default 05'400ex
no seperate tranny lube, but I don't know what could be causing your hard shifts
Old Apr 13, 2008 | 05:26 PM
sdm111's Avatar
2 strokes or 4
Default 05'400ex
O.k.thanks
Old Apr 14, 2008 | 06:54 AM
eddieo51's Avatar
Default 05'400ex
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 14, 2008 | 07:06 AM
eddieo51's Avatar
Default 05'400ex
[img]i/expressions/face-icon-small-frown.gif[/img]Ihave a 2005ez400, it uses the same oil for the Engine an trany,Mite want to check you clutch linkage,Also try Honda syn 10/40 motor cycle oil on you next change,or a good different brand,I like Bey-Ray ,but the chose is yours,If the clutch is draging that will make it haed to shift!! I havent had any problems with my 2004&my 2005 EX,s.You mite have a broken clutch spring, or if you put a HD clutch pack in,some times the springs are to stiff.I will stagger them,I stock&1 Hd and so on. Hope this helps.Eddie.
Old Apr 14, 2008 | 09:28 AM
sdm111's Avatar
2 strokes or 4
Default 05'400ex
Thanks it's an all stock bike with honda hp4 oil, I'll look into the clutch thanks again
Old Apr 14, 2008 | 10:51 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 05'400ex
The Honda 450R is the only quad that seperates the engine and transmission oil. (Not sure about the new 700XX????)
Your EX shares the oil between the engine and transmission. This means your oil unfortunately has to do double duty. Transmissions thrash your oil at high pressure....
Good read: http://www.thumperfaq.com/oil.htm
Old Apr 14, 2008 | 09:30 PM
sdm111's Avatar
2 strokes or 4
Default 05'400ex
Thanks Reconranger good writeup
Old Apr 14, 2008 | 09:53 PM
sdm111's Avatar
2 strokes or 4
Default 05'400ex
O.k. I've narrowed it down to 2 Maxima, and Belray Reconranger which one would you advise, and synthetic blend, or full synthetic and why?Thanks
Old Apr 14, 2008 | 10:05 PM
Dans 07400ex's Avatar
Default 05'400ex
maxima
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
