yogurt
Old Apr 13, 2008 | 06:02 PM
McKay5858's Avatar
Default yogurt
on my way to milk yesterday my ds was running great but then goin down the road in fifth it jsut quit, stopped, started it right back up and carried on, when i got to the barn i checked the oil, it was straight up cottage cheese. i have since ripped the engine out, i have a head gasket here and i'm ordering new water pump shaft and seals tomorrow and i figured since i have it out i'd put a je 11.5 piston in as well. the head gasket looked perfect the seals looked pretty good but the shaft did have a little roughness to it were the seals ride, is that enough of a problem to cause the yogurty oil? the cylinder looks awsome so i cant think of anything else it could be. what else should i be checking or replacing while this engine is out and ripped apart? and how much should i expect to pay for that shaft and seals? and how do i get all that milk out of my engine now? sorry for the novel, thanks for the help
Old Apr 13, 2008 | 08:17 PM
jusrlax's Avatar
Default yogurt
For rebuilding the water pump, I got the BMW part numbers from the "F650.com" website, which is the BMW dual sport bike that uses the same motor that we have. BMW has a kit that has the plastic impeller already mounted on the shaft (which makes things much easier), as well as two new seals and a new brass o ring for the coolant drain. I ordered this kit from a BMW dealership in Northern California, and had it within a couple of days. Seems like everything costed around $75.
Old Apr 14, 2008 | 12:22 AM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
Default yogurt
mmmmmmm, Yogurt
Old Apr 14, 2008 | 08:33 AM
McKay5858's Avatar
Default yogurt
i didnt have a hard time gettin the impeller off at all so i'll just get the shaft and seals i think. i was also wondering if i have to hone the cylinder before i put the new piston in, i know its nikisil plated or whatever they call it so i wasnt sure. my biggest concern right now is how i get all that gunk out of the rest of my engine. my roommate suggestd fillin it with diesel fuel then crankin it for a couple seconds to get it to the top of the motor then draining it.
Old Apr 14, 2008 | 09:06 AM
Entomber's Avatar
Default yogurt
Yes Hone the cylinder....got it apart might as well do it right.
Old Apr 14, 2008 | 09:08 AM
McKay5858's Avatar
Default yogurt
ok, a couple of people have told me that you dont hone a nikisil plated cylinder because it takes the coating off
eightyhd
Dec 5, 2012 09:25 AM
BlackRaptor
Jan 17, 2005 01:08 AM
