question on piston ring size
Old Apr 13, 2008 | 09:40 PM
jflib74's Avatar
Default question on piston ring size
I purchased a 2000 warrior that smoked I tore down the head and jug because I could see in the exhuast port the valve seal was leaking it was wet. It actually turned out the valve guide was broke. While I have it apart I would like to replace the rings how do I know what to get size wise? The cylinder and piston look great. Any help would be great thanks Jason.
Old Apr 14, 2008 | 11:18 AM
Ujoint's Avatar
If the piston has ever been replaced, there should be the over-size marked on the top of it (ie. 0.25, 0.50, etc - which is measured in milimeters - mm) - although a Wiseco piston will have the part# stamped into it, determining the size in this #. Standard size on the 350 is 83.00 mm. You may have to measure the piston skirt with a caliper to find your size - if the caliper only reads inches, multiply the inch size by 25.4 to come up with the mm size.
Wiseco rings only fit Wiseco pistons.
Old Apr 14, 2008 | 06:34 PM
jflib74's Avatar
hey thanks for the help on the top of the piston is has this #4419m08300 and then on the other side of the top it says 6428h with an arrow which i believe means exhaust side do any of these #s look familair? thank you Im gonna have to go get a caliper to measure the jug!
Old Apr 15, 2008 | 09:16 AM
Ujoint's Avatar
You have a Wiseco piston - - 4419 is the model (fits Warrior, Wolverine, Big Bear/Moto 4, and the Kodiak 400)
08300 is the bore size - 83.0 mm, so you are running a Standard sized piston -
You will have to buy Wiseco rings to fit it.
Old Apr 15, 2008 | 07:12 PM
jflib74's Avatar
you are the man whos better then you! thank you so much for the help!
Old Apr 15, 2008 | 10:51 PM
Doctorturbo's Avatar
GOT BOOST!
Be sure to hone the jug before you put the new rings in.
robert301972robert
Aug 30, 2015 11:34 AM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
southbayman
Jul 24, 2015 09:30 AM
clsharky
Jul 13, 2015 02:07 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
