oil in front transfer case
Old Apr 14, 2008 | 12:04 PM
fireman659's Avatar
Default oil in front transfer case
Im Confused what oil should i use in my front transfer case. the manual say to use the demand drive fluid. But I have heard that the manual is wrong and i should use the LT instead. Also how do i tell if i have ADC? I have a 2006 sportsman 500X2
Old Apr 14, 2008 | 01:07 PM
markshop's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: fireman659
Im Confused what oil should i use in my front transfer case. the manual say to use the demand drive fluid. But I have heard that the manual is wrong and i should use the LT instead. Also how do i tell if i have ADC? I have a 2006 sportsman 500X2</end quote></div>
Lt fluid is the correct fluid for your machine. adc didnt come out untill 07
Old Apr 14, 2008 | 01:46 PM
fireman659's Avatar
i thought the LT fluid was for ADC
Old Apr 14, 2008 | 02:48 PM
sheepdogMSP8117's Avatar
i thought the LT fluid was for ADC</end quote></div>You're right. The LT fluid is "specifically" for front diffs with ADC, but it is also compatible with non-ADC diffs. Whereas the regular Premium Demand Drive fluid should NOT be used with ADC.
As far as which to use, I'd use what's already in there. When you drain the fluid if it has a dark green tint to it, then thats the regular fluid. LT fluid does not have any colored tint to it.
My 500 has only used the regular fluid. I'll continue to use it until I can't get in any more.
Old Apr 14, 2008 | 02:54 PM
markshop's Avatar
The lt fluid superseads the demand drive fluid. It can be used in both adc and non adc. The demand drive fluid is no longer being made and will run out on the shelves. What you cannot do is run demand drive fluid in a adc differential.
SDR-II
Sep 29, 2015 01:06 AM
RticKwad
Jul 21, 2015 03:00 PM
ghost civic
Jul 19, 2015 10:13 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
