New top end & fouled plug.
Old Apr 15, 2008 | 12:42 AM
Jud 's Avatar
Default New top end & fouled plug.
I picked up my 200x on Saturday from the shop. I had it bored out and the piston replaced. I have ridden it less than an hour and the spark plug has fouled. Is this normal. Also, the guy who did the work for me recommended that I go through 2 tanks of gas for the break in and not to over do it while breaking it in. Any thoughts or advice.
Old Apr 15, 2008 | 09:41 PM
SMFREY's Avatar
He is correct
The engine will get better as you go but it should not foul plugs
I would talk to the rebuilder again
I would also document facts if needed in future
Good luck
Ray
Old Apr 15, 2008 | 11:11 PM
Jud 's Avatar
Thanks for the info.
Old Apr 16, 2008 | 12:19 AM
Yammer rider's Avatar
Does it smoke at all? There is an o ring between the jug that could of got messed up and will pump oil in to the cylinder instead of goin to the cam
Old Apr 16, 2008 | 11:50 PM
Jud 's Avatar
I smokes a little bit when first cranked. Black smoke. I called the guy and he said the float and needle in the carburetor need to be replaced and that the fuel is burning rich. I took it back to him, so I'll know soon.
Old Apr 16, 2008 | 11:54 PM
Ya if you are running pretty rich you will foul a plug. What brand of spark plug do you use? Iv had the best luck with ngk in my X
Old Apr 17, 2008 | 12:08 PM
SMFREY's Avatar
I would get fixed ASAP as a fresh engine running rich like you are describing BAD
You could washout wour new rings
This would have been a waste of money at that point
I would pickup a carb kit
If you can get a float cool
Clean carb then run and yea the NGK plug
Also you might want to recheck the valve adjust and timing since it has a couple hours on now
I would also change oil as the issue of to much fuel will contaminate your oil and could cause other issues
Thanks
Ray
QuadRiders
Oct 22, 2015 04:13 PM
2many2ride
Sep 27, 2015 04:35 AM
kbazzy
Sep 26, 2015 11:26 AM
jsmit116
Sep 18, 2015 10:34 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
