Front End Bent 250sx?
Old Apr 16, 2008 | 04:19 PM
stevehenderson's Avatar
Default Front End Bent 250sx?
I bought a 250sx a while back pretty cheap because the front end
seamed bent. I thought it was forks because one seams to set further
back than the other making the front wheel cockied--not tracking
straight down the road. I got a new/use set of forks--same problem.
Would you guess my tree is bent or maybee the front axle or are these
front ends just a bear to get lined up after they were apart?
Any common things that get bent or ways I can check things?
Or things I might be doing wrong?
Old Apr 16, 2008 | 05:10 PM
runmedown's Avatar
sounds like the tree/ trip clamp. a slight offset in the clamp will equate to a big diff at the end of the fork due to the length-magnification factor. Try heating it with a torch and finesse it out with a sledge hammer.
Old Apr 17, 2008 | 04:08 AM
Is this what you meam by the clamp?
http://cgi.ebay.com/ebaymotors...item=160227033067&rd=1
Old Apr 17, 2008 | 10:00 AM
sdm111's Avatar
2 strokes or 4
Yeah sounds like you need trees, and thats them just watch when you take the old ones off cause the bearings are going to fall out. When you install the new ones use some grease on the top of the frame and the bottom of the tree to hold the bearings in place.
STLyamwar
Jul 25, 2020 04:44 AM
metal249
Jul 28, 2015 09:35 AM
carolinabomb
Jul 26, 2015 08:40 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
