Need help
Old Apr 16, 2008 | 11:51 PM
Lhduce's Avatar
Default Need help
What is the best streering stem for the money. Ive see a few on ebay also i see ppl talk about the tbr. I just want a good stem that does not cost alot of money. Also Is there manual i can buy to help me with changing the coolant and oil and spark plugs. I just pick up a ds 650 2006 it has bent stem. So before i mod it i want to make sure the rest of the bike is on lock any help would be great. Also what is good brake and clutch lever? thanks again guys..
Old Apr 17, 2008 | 12:32 AM
cynick's Avatar
Default Need help
Keep checking freebay, the stock stems are pretty tough. As far as a manual, all you can get is the one on disc from freebay as far as I know.
The oil is a breeze, drain the crankcase and also the tank under the front end, the filter is on the right side and they take almost 4qts. The coolant change will also be a little messy, pull the lower rad hose off and also the one from the water pump.
I think ASV makes levers for the DS also, hope this helps.
Old Apr 17, 2008 | 12:49 AM
Lhduce's Avatar
Default Need help
<div class="FTQUOTE"><begin quote>Originally posted by: cynick
I think ASV makes levers for the DS also, hope this helps.</end quote></div>
Does anyone make a cheap lever just replacement. not full lever
Old Apr 17, 2008 | 12:53 AM
cynick's Avatar
Default Need help
Don't know, may be just as cheap to get oem.
