water in cvt in outlander help
Old Apr 17, 2008 | 06:55 PM
330's Avatar
330
Default water in cvt in outlander help
i have a friend who has an 06 outlander 800 when he goes through medium depth water his belt slips until it dries out anyone have this problem and what to do to stop it any help appreciated
Old Apr 17, 2008 | 11:38 PM
RickCJ7's Avatar
Doesn't Can Am have an updated cover to install???
Old Apr 17, 2008 | 11:41 PM
Mattinthehat's Avatar
if you do a thread search you should find lots of info on this.
Basically there are 2 things to look at. Is the water getting into the CVT case through the breather or exaust, or is it coming in through a crack in one of the seals.
if it is coming in the breather or exaust the answer is easy, he needs snorkles. which again if you do a thread search is easy to find on here on how to snorkle the outlander.
if it is coming in through the seals there are a few things he can do to fix that as well, which you will also find. But most importantly. he should take it to the dealer. if it is an 06, it should stil be under warranty. so if the seals are leaking the dealer should fix it.
Old Apr 21, 2008 | 01:59 PM
Tigerracer's Avatar
I have an 06 Outty that had the same problem. Take it to the dealer and tell them you need the replacement cover kit installed. You probably will still have to pay the $50 deductible, but if you get something else replaced under warranty, they should all be covered under the same $50. I haven't had a problem slipping when wet since they fixed that problem.
Customer Service #1
May 15, 2020 08:46 AM
bigred20653
Oct 2, 2015 10:05 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
