raptor 660 problem
Old Apr 18, 2008 | 10:27 PM
raptorracer660's Avatar
Default raptor 660 problem
My 01 raptor idles out of wack. Sometimes out of nowhere the bike will start idleing real high without me touching the throttle.I have to keep playing with the choke. thanks for any help.
Old Apr 19, 2008 | 05:38 PM
ryenol's Avatar
Do you work on your own equipment? I would try the process of elimination.
Maybe take a can of starting fluid, and with bike running spray a little around the intake boots, and see if it revs up, possibly indicating bad seal allowing it to suck in air.
turn off the fuel, disconnect the fuel lines and blow through them to make sure they are clear.
Then you could take the carbs off and clean them out, be very carefull not to misplace and parts.
These are just a few small things.
Old Jun 8, 2008 | 06:38 PM
gdiddy23's Avatar
check throtle cable! Does engine race when handle bars are turned and then idle when straight?
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
