Honda 200s wont stay running
Old Apr 19, 2008 | 04:51 PM
makochris's Avatar
Default Honda 200s wont stay running
Hi I'm a new Member Guys nice to meet u all I have a honda 200S it wasnt starting so I cleaned the carb. and went to start it and it starts for about 5 seconds then turn off and if u pull it again it does the same thing what should I do?Thank U all for your help
Old Apr 20, 2008 | 08:39 PM
SMFREY's Avatar
How did you clean carb as it sounds like it is still plugged up
Ray
Old Apr 20, 2008 | 10:55 PM
hondabuster's Avatar
Are you using the choke? Will it keep running, if you blip the throttle? Have you tried raising the idle speed?
Welcome to the forums
Old Apr 22, 2008 | 03:28 PM
makochris's Avatar
I cleaned it real well took it a apart and soaked it when I go to start it it starts then dies if i give it gas it starts to bog then dies and when i go to use the choke it wont start and yes i tred raising the idle speed? Doent help do I need to rebuild the carb.? Thanks for all u guys help
Old Apr 22, 2008 | 06:59 PM
SMFREY's Avatar
Try putting the choke on part way as soon as it starts
You need to establish if it is getting somuch fuel it won't run or not enough
So
As soon as it fires up move choke about halfway maybe a little more
This will establish the answer
If engine is to lean(not enough fuel) then the engine should pickup and run
If to Rich (to much fuel) it will die
Most likely from what you describe your engine is way lean
have you checked your spark plug if not pull and describe the color
And if wet or dry
Thanks
Ray
Old Apr 22, 2008 | 07:46 PM
makochris's Avatar
Hi Ray Thanks for all your Help When the choke is all the way up it starts if I go to move the choke down it will die and it will not start if the choke is all the way down it wont even start I pulled the plug and therse a little black on it and its a little wet not alot just a little mosture u think its sound like its a carb. prolblem ? U think i Should rebuild the old carb for around $25 or get a new one for $65 Thanks for all your help ray and i noticed when i went to start it today there was some gas leaking out of the bottom over flow vaulve there was a little gas that leaked on the floor just a little What do u think i should do next ? Thanks Again Chris
Old Apr 22, 2008 | 08:07 PM
SMFREY's Avatar
From what you are describing it is rich
It would be up to you
Were it mine I would go for the new carb at $65
Worst that would happen is it not work but you would have a new carb to work with
I would look on dratv.com they have carbs
Thanks
Ray
Old Apr 23, 2008 | 08:25 PM
makochris's Avatar
Hi Ray yes I found out that it is running rich is there a way to fix it with the old carb? Or would it need to be rebuilt? Thanks For all your help
Old Apr 23, 2008 | 10:02 PM
makochris's Avatar
hea ray it will stay running when in idle for a while but when i go to give it gas on thotle it dies ? U think I should just buy a new carb ?
Old Apr 24, 2008 | 12:38 AM
SMFREY's Avatar
We need to back up
I went out and looked at the carb that came off my 185
Same basic carb as yours
If the choke lever is down the choke is open
If lever is up choke is closed
So
Your carb should be the same you could confirm but I an sure
So that means your engine likes running with the choke on
And as soon as you move the choke it dies
If you open throttle it dies
I am getting a handle on this
your engine is running lean which means either your carb is still plugged
Or you have a Vacum leak in the intake system
I just looked
A carb kit on dratv is about 16 a parts dip is about 26
New carb is about 49
Heck try a new carb for that kind of money it comes out as a wash
Thanks
Ray
