Honda 200s wont stay running
Old Apr 24, 2008 | 01:36 PM
makochris's Avatar
Default Honda 200s wont stay running
Yea It only runs when the choke is all the way in the up postion And I did order new carb on Dratv thanks for that web site when I get it and put it in I will keep u posted and realy Ray I want to thank u for all your help .Thanks Chris
Old Apr 29, 2008 | 11:08 AM
makochris's Avatar
Hi jay Put that New carb on and it runs good the only thing now is it leaks a little oil in the head gasket . Thanks for all your Help
Old Apr 30, 2008 | 12:44 AM
SMFREY's Avatar
You could retorque the head bolts
The book says tighten the 8mm Cap nuts to14 ft-lb
And the 6mmAllen bolts to 9ft-lb
I would give this a try
I am glad the carb worked
I just ordered a bunch of stuff from dratv
For one of my 110s and my trail 70 in getting going again
I will probably get carb for my 185s in June
After dune trip
Thanks
Ray
Old Dec 14, 2021 | 06:26 PM
Salyt77's Avatar
Originally Posted by makochris
Hi Ray Thanks for all your Help When the choke is all the way up it starts if I go to move the choke down it will die and it will not start if the choke is all the way down it wont even start I pulled the plug and therse a little black on it and its a little wet not alot just a little mosture u think its sound like its a carb. prolblem ? U think i Should rebuild the old carb for around $25 or get a new one for $65 Thanks for all your help ray and i noticed when i went to start it today there was some gas leaking out of the bottom over flow vaulve there was a little gas that leaked on the floor just a little What do u think i should do next ? Thanks Again Chris
I have a brand new carb that matches exactly with Keihin Japan name on the original carb and I am having the same issue with my start up as it only runs for five seconds and shuts off even if you try and give it some throttle so must just be an adjustment issue I believe but not sure as I added a inline fuel filter but don't think that is the issue.
Old Jan 26, 2022 | 10:13 AM
  #15
LBWest's Avatar
Default Have you tried hotter Spark plug?
Hey there I had the same problem with my ATC what worked for me was replacing the spark plug with a hotter plug. Did that and problems no more! Try it!
Old Oct 18, 2022 | 11:48 PM
  #16
JunkFixerUpper's Avatar
FlipperFixer
You remember what plug that was?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Land_shark1
Jul 10, 2015 12:53 AM
jayking232003
Jun 9, 2015 02:54 PM
blaze_master
May 26, 2015 11:18 AM
lovinhonda
Jan 25, 2000 09:17 PM
