chain [o-ring or not]
I have a 500 scrambler and I just put a new chain the old one was o ring the new one isn't. Now there is a bad grinding noise . Is this anything to worry about or will it go away. I rode for about 2 hours and it still does it. no beter no worse. please help thanks
Welcome to the forum jfells! [img]i/expressions/face-icon-small-smile.gif[/img]
I would expect some noise going from a non oring to a oring. (oring chain is wider than a non o ring) Any ideas where the noise is coming from?
you sure the chain is right and its not meshing w/ the sprockets and grinding. look at it to see if its all shiney from actual grinding. O ring chain are great on street bikes, but think they would get eaten up by the mud and did fast.
<div class="FTQUOTE"><begin quote>Originally posted by: stendori O ring chain are great on street bikes, but think they would get eaten up by the mud and did fast.</end quote></div>
O-ring chains are excellent for mud and dirt. I use one on all of my dirt bikes.
Well not all of them....the XR75 and Mini trail have non oring chains.
Most also need to replace Sprockets when the chain wears...........That's what I been told!!....Caper........
If the sprockets are worn to the oring chain that could cause your noise.I like the O ring chains in dirt and mud that wont stretch as much as a nonOring.I do like the non Orings on my Harley due to the clearances.
O ring chains would last longer for sure when there well lubed, see learn something new everyday. [img]i/expressions/face-icon-small-smile.gif[/img] i stilll like shaft drive over chain though lol.
<div class="FTQUOTE"><begin quote>Originally posted by: caperinmuskoka
Most also need to replace Sprockets when the chain wears...........That's what I been told!!....Caper........</end quote></div>
[img]i/expressions/face-icon-small-happy.gif[/img] i AGREE,SPROCKET WEAR WOULD BE THE CULPRIT. I alwas replaced the sprockets when replacing the chain. New chain most likely is not meshing with the old/wore sprockets!!!!![img]i/expressions/face-icon-small-frown.gif[/img]
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
