Proper Use of AWD System
Old Apr 20, 2008 | 11:50 AM
MaineWheeler's Avatar
Default Proper Use of AWD System
ATV is a 99 500 Magnum 4x4 and I am new to it and have heard that it can be put into AWD on the move like a 4x4 pickup- 2 versions though, 1-only while in High Gear, 2-It didn't matter High or Low as long as it was not under harsh conditions. I also have heard that I should NEVER attempt to engage while moving, what is the proper use of the system? Thanks for any and all time spent answering this for me guys. MaineWheeler
Old Apr 20, 2008 | 01:14 PM
800 Mossy Oak's Avatar
The most important thing to remember is never put it into 4wd while the rear wheels are spinning(not moving)but spinning.It does not matter if it is in low or high!! Happy trails.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 20, 2008 | 01:48 PM
MECHANIKE's Avatar
yeah like 800 says if your spinning your rear tires, weather its on gravel,snow, mud,especially stuck+spinning,dont push the button cause,it will slam into the hubs or diff,with a greater degree of force than normal,usually shattering the hilliard clutch.there is a safety rev limiter that doesnt allow engagment but you can still destroy at lower rpm.
Old Apr 20, 2008 | 02:31 PM
TLC's Avatar
TLC
But if it does slam into 4wd while in a stand still spin,the old hub system has a much higher probability of survival then the new front diff with its plastic cage. Thank for the reverse improvement Polaris.
If it works change it.
Old Apr 20, 2008 | 04:33 PM
jodaanja's Avatar
As the others said....Hi or low.....The front wheels must be equal in RPM to the rear.....Could be 0 rpms, could be 60 mph......As long as there is no speed difference between the front and rear wheels. As soon as you hit AWD, the speeds will instantly be syncronized. If there is a big differencein rpm, it puts severe shock on the driveline. Maine here too. What city/town are you in?
Old Apr 20, 2008 | 06:42 PM
MECHANIKE's Avatar
10/4 TLC, INSTEAD OF TWO ALUM. HILLIARDS, THEY PUT ONE PLASTIC ONE.IS IT AT LEAST BIGGER THAN THE OLD HUB HILLIARDS? I'VE BEEN BUYING HUBS+HILLIARDS ON E-BAY SINCE MY DRUNKIN BROTHER-IN LAW EXPLODED A HILLIARD+HUB,I FLY ON THIS 01SCRAM 500 4X4IN4X4IN ALL EARTH OBSTICLES,+NEVER YET HAD A problem.
Old Apr 21, 2008 | 08:16 AM
So if I'm understanding all -- If I am just rolling along and NOT spinning my rear tires as stuck and spinning I CAN engage the AWD system - A for instance is, I'm going down the trail NOT stuck just cruising and I see/know there is a bad mud spot ahead I can kick in the AWD sys as long as its BEFORE I get into it and ALL 4 wheels are still spinning at the same speed.----On my 99 the AWD system is in each INDIVIDUAL front hub NOT the center differential. Does the above info still apply?
Old Apr 21, 2008 | 09:15 AM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: MaineWheeler
So if I'm understanding all -- If I am just rolling along and NOT spinning my rear tires as stuck and spinning I CAN engage the AWD system - A for instance is, I'm going down the trail NOT stuck just cruising and I see/know there is a bad mud spot ahead I can kick in the AWD sys as long as its BEFORE I get into it and ALL 4 wheels are still spinning at the same speed.----On my 99 the AWD system is in each INDIVIDUAL front hub NOT the center differential. Does the above info still apply?</end quote></div>
Yes, its shift on the fly! just like your 4wd truck.
Old Apr 21, 2008 | 12:37 PM
Hawkman300's Avatar
with my hawkeye, you can engage AWD anytime and it just waits until it gets to a preset rpm to engage. the only time you shouldnt engage AWD is when the rear wheels are already spinning, like ure in 2wd in mud and switch it to AWD with rear wheels spinning because it will jerk the front wheels to engage.
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
