Honda 250 recon
Old Apr 21, 2008 | 12:53 PM
The Bazz's Avatar
Default Honda 250 recon
Does anybody know what to do when the start pull cord wont go back in on a 250 recon.
Old Apr 21, 2008 | 03:21 PM
yamaharap's Avatar
try tapping the metal peice where the pull start coils back down in with a hammer , sorry dont know what its called
Old Apr 21, 2008 | 10:22 PM
chevytrucks1994's Avatar
i have the same problem.damn thing wont go back in but its stupid because u shut the key off and pull it out slitley and let go it goes in on mine.i dont know if it does on yours because mine i bought used and it was a 2004.now i just got a viper winch to mount on it and the damn mount im fabricating and since i bought it the fourwheeler wasnt running right (murphy's law).it stopped running at the bottom of my driveway and so i pulled it behind my house with the tractor to work on it and i got a new spark plug and it ran so i took it on my trail and came back and it ran fine.the day after (today) it ran and i went to wash it and it started and i pulled it out and shut it off and it was running fine.when i went to turn it back on it did the same thing where it would start but id have to keep the choke on when its 75 degrees out and keep on the gas.after that i decided to call naults honda to see what the problem was and they told me to drain the carb so thats what i did and it didnt work. now its in my back yard and i took the battery out to charge it and the spark plug and the brand new spark plug smelt like gas and was just about as black as the old one.does anyone know what the problem might be
Old Apr 23, 2008 | 12:00 PM
The Bazz's Avatar
Thanks for the help. I was able to fix it last night by removing the plate that holds the spring and cord. all one assembly. Only 3 small bolts. The spring was bound up with rust and mud. I washed it out with water then wd 40 and it started working again.Reassambled and it works fine.
Old Apr 27, 2008 | 08:47 PM
oh thats good.i thought yours was like mine,it doesnt go in all the way and leaves like an inch. of slack so i found if i shut it off and pull it it goes in.
Old Apr 27, 2008 | 09:31 PM
mudb0ggers's Avatar
i was wondering i need new tires for my 06 250 recon
do the mudlites make it go any slower?
would i need new rims?
wat other tires are good for a recon(back only)
Old Apr 27, 2008 | 09:42 PM
im planning on getting mud lites for my 04 recon but u dont need new rims.if you want to use the stock rims id say to get 25x12-9 it would fit the rim but it would be bigger because the stock tires are 22 x 10-9. The other tire that would be good is a mud bug and those come in the same size as stock.both tires are good for a recon because they are light.im not sure on any others. http://www.maxxis.com/products...duct_detail.asp?id=56
theres a link for mudbugs
Old Apr 29, 2008 | 05:48 PM
mudb0ggers's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: chevytrucks1994
im planning on getting mud lites for my 04 recon but u dont need new rims.if you want to use the stock rims id say to get 25x12-9 it would fit the rim but it would be bigger because the stock tires are 22 x 10-9. The other tire that would be good is a mud bug and those come in the same size as stock.both tires are good for a recon because they are light.im not sure on any others. <a target=_blank class=ftalternatingbarlinklarge href="http://www.maxxis.com/products/ATV/product_detail.asp?id=56
">http://www.maxxis.com/products...etail.asp?id=56
</a>
theres a link for mudbugs</end quote></div>
__________________________________________________ __________-
can i get your real email because i got some questions...
about tires for my recon
i want to get the kenda bear claws
wats size tire would i need to get to fit the stock rim?
wendal
May 9, 2024 09:29 PM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
