Headlights on Raptor
Old Apr 21, 2008 | 11:17 PM
raptor2006350's Avatar
Default Headlights on Raptor
I believe I am over analyzing putting the headlights on my Raptor 350. There are 2 bolts that hold the light onto the bracket. Then there is a slot at the bottom that holds a grommet that slides onto the frame. When I tighten the 2 bolts to the bracket on the frame the bottom slides out and then the light is not lined up. There seems like there should be a nut and bolt that holds the bottom on but don't think there is. What am I doing wrong?
Old Apr 22, 2008 | 12:01 AM
Raptor450's Avatar
Make sure the **** at the bottom is not bent. Also make sure you have the spacers in the top bolts that slides into the grommets. The light kind-of just hangs there, it's never really tight to the frame or bracket.
Old Apr 22, 2008 | 12:34 AM
Well that's crappy engineering. Thanks.
bmxatv10
Oct 14, 2022 06:23 PM
Whitelx1
Oct 2, 2015 10:55 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
