Renegade 500 pipe again
Old Apr 22, 2008 | 10:05 PM
number1_kid's Avatar
Default Renegade 500 pipe again
DOes someone know for 101% if thor the Utility series HMF slip on for the 800 Renegede fits on the 500 ???? Thanks
Old Apr 23, 2008 | 07:59 PM
troy32's Avatar
Check out the BRP Can-Am website and go into the Parts Schematics area. See if they are the same part # on both. Or, call a dealer and have them do it for you. If they are the same part number, you will have your answer. I recently bought an HMF Penland Utility slip-on for my ride. While HMF doesnt show it as a pipe for the 650Max, I cross referenced the part numbers. Turns out the 800Max and 650Max share the same part number. So, I went ahead and bought the pipe and it bolted on perfectly. I went with the Penland to get the Torque Range Modifier piece that creates a slight improvement on low-end torque. Other than that, I believe it is same pipe as the Utility Series.
Mar 21, 2016 06:30 PM
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
1000gade
Sep 9, 2015 04:41 PM
