Renegade 500 pipe again
Check out the BRP Can-Am website and go into the Parts Schematics area. See if they are the same part # on both. Or, call a dealer and have them do it for you. If they are the same part number, you will have your answer. I recently bought an HMF Penland Utility slip-on for my ride. While HMF doesnt show it as a pipe for the 650Max, I cross referenced the part numbers. Turns out the 800Max and 650Max share the same part number. So, I went ahead and bought the pipe and it bolted on perfectly. I went with the Penland to get the Torque Range Modifier piece that creates a slight improvement on low-end torque. Other than that, I believe it is same pipe as the Utility Series.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
