winter plug
Old Jan 20, 2001 | 10:59 AM
atc86r's Avatar
what plug do i use on my 84 aircooled atc250r in the snow?
Old Jan 22, 2001 | 08:34 PM
fivel250rman's Avatar
Try the same one you use in the dirt.Is your plug fouling,then your jetting is what you should be checking out.Tell me more about the problem you are having and maybe I can help.
88' 250R many extras
Old Jan 22, 2001 | 10:54 PM
scramdaddy400's Avatar
Switch to a cooler plug for temps. below 25 degrees.
A cooler plug is always the next size up, lets say you had a b8es if you want a cooler plug you go to a b9es.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Jan 23, 2001 | 07:42 PM
nsayne's Avatar
huh??? I may be wrong but last time I checked I would go with a hotter plug in the winter. If you have a service manual for your bike it may say what to run. If not I would not change from what you are already using unless you are experiencing fouling or other running probs. (If it ain't broke don't fix it)
Old Jan 23, 2001 | 08:30 PM
This only applies to two strokes.
This is going to sound weird so i'll try to explain it as clear as I can.
In temps. below 25 degrees running a hotter plug can cause spark failure. What happens is the engine is running hotter than the spark plug and the plug heats to the point were it can't spark right and your machine dies, you think you have a fouled plug but its really gotten hot to the point where it won't function.
Running a cooler plug can prevent that cuz its running at or below the engines temperature providing a consistant spark for the cooler weather.
Once temps. reach to above 25 degrees its time to change back to a hotter plug.
I know this is all confusing but I helped Xplor with the same problem he had with his scrambler dying in the winter.
SCRAMDADDY400
Old Jan 23, 2001 | 11:25 PM
nsayne's Avatar
there ya go you learn something new every day
Hankey Pankey
May 1, 2018 01:33 PM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
Gtsordo
Jul 22, 2015 01:27 PM
