How to check for spark
I have a quad that will turn over but won't fire. I put a new plug in and still no fire. How do I check to see if I'm getting spark, and if i'm not getting spark what could be the problems. Thanks Breck
just remove the spark plug, reinstall the spark plug wire to the spark plug, lay it on the cylinder to ground it, if it doesn't stay on its own then use a piece of duct tape to hold it in place then crank the engine over while looking at the spark plugs electrodes, while cranking you see a spark, if you see no spark make sure the handle bar switch in the run position, also the rear brake needs to be applied. if their's a red bottom on the switch press it in, then crank the engine over again and recheck for spark, still no spark start looking for a loose wire, this is one the the biggest problem with these chinese quads poor wiring connections
<div class="FTQUOTE"><begin quote>Originally posted by: onebigzj
I always have my wife hold the plugwire and turn it over. If she screams its got spark. if she doesent I find something that does have spark. and try again</end quote></div>
a real man would hold it themselves and don't frget to wet the finger before inserting it into the spark plug cap
<div class="FTQUOTE"><begin quote>Originally posted by: chineseatvmechanic
a real man would hold it themselves and don't frget to wet the finger before inserting it into the spark plug cap</end quote></div>
my wife was a real man[img]i/expressions/face-icon-small-confused.gif[/img]
