Polaris trailboss 250 1992
Ok we are having a electrical issue maybe, i went through the whole wheeler found a bad voltage rectifier, a bunch of loose wires and fixed everything, but now into the problem. when we have the cdi box's black wire connected to it terminal the wheeler will shut off and won't start- sometimes, other times it will be running unhooked and will die then you hook it up it will run again, for a while then die again, as i said i went threw all wires and switches cot a new ignition switch, volt rectifier, unhooked emergency shutoff switch to ensure a open connection, and also i almost forgot with the cdi black wire unhooked the ignition switch will not kill the motor? i think the CDI Box is fried anyone have any ideas?? before i spend 220.00....thanks
