SunL 150 atv
Old Apr 27, 2008 | 05:49 PM
kaysandee's Avatar
Default SunL 150 atv
Is there anyone who can help with a loose chain. No experience here and no shop for miles and miles. 2005 model. The chain is loose and hitting/sitting on the shock bolt. Is there a way for a newbie to tighten the chain? Thanks for any help, I'm a lady, but I'm pretty good with a crescent wrench. The owners manual isn't worth a toot! If anybody can give me a step by step I sure would appreciate it.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 28, 2008 | 11:33 AM
chineseatvmechanic's Avatar
to tighten the chain, their is 4 bolts holding the rear axle housing onto the swing arm, the top two are the pivot bolts, the bottom 2 are the sliders, loosen (do not remove), all 4 bolts, they should take somewhere around 17-18mm wrench, once the 4 bolts are loosen then look on the bottom side of axle housing you will see 2 studs with nuts on them, these are the adjusters, when you tighten the nuts it pulls the axle back, tighting the chain, make sure you turn each nut the same so that the axle doesn't misalign , do not over tigten tighten the chain , you still want appox 3/8" slack in the chain after adjusting. then tighten the 4 bolts back up, youre done.
Old Apr 29, 2008 | 07:07 PM
kaysandee's Avatar
THANK YOU THANK YOU THANK YOU! WILL TRY IT THIS WEEKEND!
Bigredjeep
Apr 10, 2020 02:55 AM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
WILLLANE8302
1) Engine problems..
Aug 7, 2015 08:24 AM
Mobyguzzer
Apr 28, 2006 11:25 PM
