need info on timing a 2000 bombardier ds650
Old Apr 28, 2008 | 08:50 PM
twohotnova's Avatar
Default need info on timing a 2000 bombardier ds650
i put a big bore kit in my motor and i need to know how to time it. and i would also like to know if i should put a rev limiter in it. i used the stock cam should i put a different cam in it or will it run good with this stock cam when i bought it they said it had low hours on it any help would be great thank you
Old Apr 28, 2008 | 10:29 PM
cynick's Avatar
First off welcome to the forums.
To time it correctly there is a allen bolt below the clutch cover, take it out and you can see the counterbalancer for the crank. Sharpen a 6mm bolt and roll the engine over until you see a ground out spot, that is where the bolt goes. Install the piston and then the head. Before putting the cams back in try getting your hands on a set of 109's or A1/A2's, this will really make the big bore run. If you haven't changed your rev box, do that cause the rev limit on a 00 is real low, I used a Vortex, Ron Woods sells a good one too and so does Big gun.
toonces
Oct 16, 2019 12:11 PM
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Mikea1978
Jul 4, 2015 12:37 PM
