anti freeze problem
Old Apr 29, 2008 | 01:26 PM
brendan143's Avatar
Default anti freeze problem
it is shooting the anti freeze out of the little white bottle and then it will start to smoke white smoke. is this the head gasket or what could it be? also i found the hose that runs from above the screw where you drain the anti freeze out was popped off from the top part of it so i put it back on and noticed it didnt ahve any anti freeze in it and then i filled it up and then it ran good then started smoking white smoke out of the baffle and anti freeze was coming out where the pipe connects by the head.
Old Apr 29, 2008 | 02:03 PM
jusrlax's Avatar
Sure does sound like head gasket. Combustion chamber pressure is getting into the cooling system, causing the coolant to come out of the overflow reservoir and maybe the hose to pop off?
Old Apr 29, 2008 | 02:06 PM
brendan143's Avatar
yes that seems exactly like what it is doing, and when i turn it over with the dran plug out the anti freeze just shoots out like 4 feet just from touching the start button for half a second
Old Apr 29, 2008 | 02:29 PM
Lhduce's Avatar
A little off topic but what is good type of anti freeze for the ds650. Other then factory
Old Apr 29, 2008 | 02:50 PM
jusrlax's Avatar
Do a search on "engine ice". That is what I use. I think it may allow the bike to run a little bit cooler.
Old Apr 29, 2008 | 05:56 PM
DSengineer's Avatar
Has been here a long time!
Sounds like your head gasket. I just went through the same thing.
Old Apr 29, 2008 | 05:59 PM
DSengineer's Avatar
Here is my prior post about this: head gasket
Old Apr 29, 2008 | 06:28 PM
brendan143's Avatar
yeah i think mine is worse tho it was puffing big puffs of white smoke out of the pipe and there was antifreese coming out on a connection point in the exhaust
Old Apr 29, 2008 | 08:32 PM
DSengineer's Avatar
Your leak definately sounds more severe than mine was. Mine would only spew coolant out the weephole at high RPM. I was not getting any white smoke either. Are you using a stock head gasket or aftermarket? High compression piston, or stock?
Old Apr 29, 2008 | 08:35 PM
brendan143's Avatar
stock head gasket and stock compression for all i know i just boght the quad. i know it is a gasket leak becasue anti freeze burns white when it gets in the
gass
