Oil question
Old Apr 30, 2008 | 06:40 PM
ChrisRider's Avatar
Default Oil question
Hey guys,
just picked up a 2002 400ex and i drained the oil and I was wondering what the measurement was for the amount of oil you put back in...Thnks!
Old Apr 30, 2008 | 07:18 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Good article. Don't put the filter in backward:
<a target=_blank class=ftalternatingbarlinklarge href="http://www.atvriders.com/articles/oilchange400ex.html
">http://www.atvriders.com/artic...hange400ex.html
</a>
Did you drain both the tank and the crankcase??? (Newbs often forget the crankcase!)
Here is what I do: Refill the tank full, which takes about 1.8 quarts. Start the engine for several minutes, and that will pump oil back into the crankcase, dry oil filter, and oil cooler. Stop the engine and check the oil level. Mine usually drops to the bottom of the dipstick, and I top it up to the top. Take it for a real ride, the recheck the oil level after and top up if necessary.
Do not overfill this machine! The pressure will blow the lines right off the tank. Also, when it sits, the oil level will be totally bogus until you take it for a short ride and then check it. (Usually just warming up the engine like the owner's manual says, doesn't result in an accurate oil level for me...I have to ride it around the block and run through the gears.)
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
