How to Fix lower ball joint on a 2001 polaris trail blazer
Old Apr 30, 2008 | 10:26 PM
mmleigh18's Avatar
Default How to Fix lower ball joint on a 2001 polaris trail blazer
How do I replace the lower ball joint on my 2001 polaris trailblazer. I cannot get the old ball joint out to put the new one in.
Old Apr 30, 2008 | 10:37 PM
ftwflh's Avatar
you need a puller to do it right.
Old May 1, 2008 | 08:43 AM
Ujoint's Avatar
The easiest way to remove a ball joint on a Polaris is:
You will need a Propane torch and a Grease Gun
1) Remove the A arm from the ball joint
2) Remove the plate holding the ball joint in
** Note - If the ball has broken out of it's socket, find a self tapping screw to fit up in the little hole in the socket still left in the strut.
3) At this point things start getting hot (watch your hands, fingers, etc) - Heat the area on the strut around the ball joint with a propane torch
4) Using the grease gun - pump grease in the zerk intended to normally grease the ball joint - this will push the ball joint out
5) After things cool a little, clean all the grease out of the socket - heat the inside of the socket back up and slide the new ball joint into the strut.
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
