87 250X Won't start
Old May 1, 2008 | 12:36 AM
trenth48's Avatar
Default 87 250X Won't start
i have an 87 250X that won't start. it's getting spark, getting fuel, has good compression, it's in timing, but it won't start. i put a new CDI box on it, i have tried adjusting the valves and the compression release, and still nothing. When i kick it every now and then it will try to start, but won't. i've tried pulling it to start it, and that doesn't work either. The local honda dealer won't work on because it's too old. I am confused! any ideas would be greatly appreciated.
Old May 1, 2008 | 11:36 PM
trenth48's Avatar
anyone have any suggestions?
Old May 2, 2008 | 12:16 AM
Basstromboon's Avatar
did you clean out the carb? If its getting spark and fuel but not starting may just be kinda clogged. Just the typical fix. Just an option. Best of luck.
Old May 2, 2008 | 12:24 AM
QWODER's Avatar
try draining the carb first and getting new fuel in carb.
Old May 2, 2008 | 12:17 PM
trenth48's Avatar
the guy that is working on it said that the stator voltage looked a little funny, but nothing that should keep it from running. i'll try cleaning the carb also.
Old Mar 25, 2009 | 12:53 PM
grhd04's Avatar
What were the results of the compression test. I now have the same problem on an identical bike. Just wondering what the compression should be?
Let you know if I come up with anything
Good luck
big_g_squared
Jun 28, 2015 04:17 PM
1000gade
May 27, 2015 12:37 PM
owen350x
Jul 30, 2000 01:58 AM
97TrailBlazer
Apr 2, 2000 03:34 PM
YellaTerra
Mar 30, 2000 04:38 PM
