raptor front wheel bearing???
Old May 6, 2008 | 01:44 PM
bwiencek's Avatar
Default raptor front wheel bearing???
Looking to replace the front wheel bearings in the '02 Raptor 660R and was wondering if anyone knew the bearing number? I've got a big bearing supply place not too far from where I work and they usually have anything I've needed in stock if I can give them a bearing number... and they're usually about 1/4 the price of the dealership... (of course the dealers don't have any in stock so that's out anyhow)
Old May 6, 2008 | 05:23 PM
Raptor450's Avatar
The bearing # should be stamped into the original bearing. They can cross reference that #.
Old May 6, 2008 | 06:46 PM
bwiencek's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
The bearing # should be stamped into the original bearing. They can cross reference that #.</end quote></div>
Figured that - just haven't pulled it apart and was hoping someone had done this before and has the bearing / seal part numbers off hand... I was hoping to pick up the parts to do the swap this weekend - otherwise it will be pull it apart this weekend, go to the parts store next week, then replace them the follwing weekend... just don't have a ton of time during the week to work on anything...
Old May 6, 2008 | 11:14 PM
Raptor450's Avatar
Usually my dealer stocks the Pivot Works kit with all the hub bearings and seals for $40. It will be hard to beat that price. It's probably best to buy the seals from a Yamaha dealer anyway.
I usually take my hubs off and take them to the dealer and have them remove the bearings and install new ones. I never figured out how to get the dang things out. They usually charge $80 for parts and labor to do it.
Old May 7, 2008 | 11:36 AM
oblytr8's Avatar
I just purchased new bearings for my Raptor, but havent installed them yet. When I get home from work today, I will post the part numbers here for the inner and outer bearings.
Old May 7, 2008 | 12:22 PM
TORK's Avatar
I have N2 parts Inner bearing $3.50 ID 15mm, OD 35mm, W 11mm. Outer bearing $6.50 ID 30mm, OD 55mm, W 13mm. Inner seal $2.00 ID 21mm, OD 35mm, W 7mm. Outer seal $2.95 ID26mm, OD 42mm, W 7mm. Hope this helps. TORK.
traumajunkie
Jun 30, 2015 04:28 AM
Rooky
10
Jun 23, 2015 09:35 PM
UPLou
Jun 7, 2015 09:42 AM
volsgo30
Jun 4, 2015 06:07 PM
