Lift or tires?
Old May 8, 2008 | 01:08 AM
1meanWolverine's Avatar
Default Lift or tires?
I have a 07 wolverine 450...where we go muddin I need alittle bit more bround clearence...I need at least about 1 1/2 inch. Would it be better to find a lift kit. And if so what kind...i have searched but could not find anything. Or maybe a set of swamp lite tires. If so what size could i fit on my stock wheels to give it alittle more ground clearnce. It can tear threw mud but it get stuck because the frame sits down on the ruts.
Old May 8, 2008 | 01:43 AM
miassmaro98's Avatar
25's-27's or buy a bruin 2" lift kit it will fit perfect
Old May 8, 2008 | 10:39 AM
pmcc37's Avatar
you won't get any more ground clearance with kust a lift, the larger tires give you the ground clearance.. I know 26's will fit without a lift, but not sure about 27's
Old May 8, 2008 | 11:39 AM
Ok i have decided to go with just tires...and i am going to go with some swamp lites...Will a 25x8x12 for the front and 25x10x12 for the back....will these fit on my stock rims?
Old May 8, 2008 | 11:49 AM
pmcc37's Avatar
yep, should with no problem.... n the swamp lites are a good choice...
Old May 8, 2008 | 12:07 PM
justhanginout's Avatar
just a suggestion you might want to put a clutch kit in it to ensure that you get enough out to turn the bigger tires. but thats just me. there are alot of threads out there about clutch kits and i'm to lazy to mention them
Old May 8, 2008 | 12:08 PM
Yeah i do alot of trail riding with it also so i figured the swampl lite would handle better than mudlits...plus the rits we go it...the swamp lites and more side wall tread on them...and actually to me they look like the could cut threw mud about as good as mud lites...and i have never doubted interco before...i have irocs on my truck
Old May 8, 2008 | 12:21 PM
those are some pretty narly tires. i was just doing a little googling on them. how much are you planning on paying for them i found a site that has them for 275 for all four thats not a bad deal at all i'm half tempted to buy me a set today
Old May 8, 2008 | 12:57 PM
for the sizes i mentioned earlier my local shop is 300 with them put on lol. So ill prolly just order them locally....
BTW has anyone sen a front locker for the 450 wolverine?
Old May 8, 2008 | 01:00 PM
thats not bad 300 for everything. cause by the time you buy them pay shiping and then put them on it will probably cost you more than 300. as for front lockers i haven't seen anything. thats the bad part about the new wolvie is trying to find mods. i guess give it a bit they are slowly coming out of the wood works
