Sport Quads Discussions on sport quads.
how do you run the fuel out of your bike?
Old May 8, 2008 | 01:18 AM
redrider52's Avatar
Default how do you run the fuel out of your bike?
i turn my gas off and run my bike till it dies to make sure theres no fuel left in the carb and lines. is that bad to do on a regular basis? is there any other ways to do it?
Old May 8, 2008 | 02:20 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
You can turn off the fuel valve, and open the drain screw at the bottom of the float bowl.
Old May 8, 2008 | 07:18 PM
redrider52's Avatar
ill try that method out. could the way i was doin it before have damaged anything?
Old May 9, 2008 | 11:19 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
No damage, but by unscrewing the drain screw you"ll be empty in a matter of seconds instead of running 5 minites. Plus you"ll be emptying her completely including any water that might be in the bowl. Just put the drain hose in a can to catch the gas and unscrew it.
Old May 10, 2008 | 01:36 PM
redrider52's Avatar
alright cool thanks a lot
Old May 28, 2008 | 11:18 PM
WaRRiOr2069's Avatar
Dont do that your carb may suck in something. you have a 52cc just flip it over and undo the gas cap. But make sure the gas falls into a container or something, cuz ist pretty damn expensive.
Old May 28, 2008 | 11:27 PM
redrider52's Avatar
yeah i got a 400 and flipin that thing over is not something i wana be doin after every ride and then taking the chance of brakin something while its on the bars.
Old May 29, 2008 | 12:54 PM
I guess that drain screw on the bowl is just for looks.
Old May 29, 2008 | 10:10 PM
redrider52's Avatar
it comes right out and drains all the fuel out. its functional. i know that. lot quicker than running the gas outa of it and whole lot easier than flippin the whole bike over to get allll the gas outa it.
Old May 30, 2008 | 12:38 AM
Baddawg's Avatar
If parking it for any length of time I add Sta-bil and run it long enough for it to run through the carb,then just shut off the fuel.Never had a problem with this method.
