Sport Quads Discussions on sport quads.
how do you run the fuel out of your bike?
Old 05-30-2008 | 02:41 AM
redrider52's Avatar
Default how do you run the fuel out of your bike?
what is sta- bil? ive heard of it before but i dont know what it actually does. does it just clean out the carb and line it with a non-corrosive lubricant?
Old 05-30-2008 | 11:35 AM
Baddawg's Avatar
Sta-bil stabilizes gas,it prevents gum and varnish.This is a brand name I'm sure there are others.It claims to keep your gas from going bad for a year,I've used it for six or eight months.
Old 06-03-2008 | 07:19 PM
BioWare's Avatar
Toxic Ryder
<div class="FTQUOTE"><begin quote>Originally posted by: CamoKodiak450
No damage, but by unscrewing the drain screw you"ll be empty in a matter of seconds instead of running 5 minites. Plus you"ll be emptying her completely including any water that might be in the bowl. Just put the drain hose in a can to catch the gas and unscrew it.</end quote></div>
Or I just run it in the winter time to get all the gas out . Then I put stabilizer in the tank for the winter months.
Old 06-04-2008 | 12:56 AM
Williebee's Avatar
I used the stabil for yrs. to winterize lawn and garden equipment , but the directions call for draining the treated fuel the following season ; i found something that works better that you don't need to drain it's called Sea Foam and it does alot more than just stabilize your fuel !
You can get Sea Foam at any Auto Parts Store , and your local Walmart should have it ; Sea Foam cost more than the stabil but it's worth the cost for what all it does for Gasoline and Deisel engine's both 2 and 4 stroke's !
Sea Foam keep's the entire fuel system clean and help's remove moisture , and clean's the combustion chamber of builtup carbon deposits as you ride and to much to put in this reply ; i've never used a product that does everything it claims to do untill i tried the Sea Foam !
Walmart had it for $5.49 and the Auto parts stores in my area had it for $6.99 + tax for a 16 oz. can that will treat up to 25 Gallons of fuel , mixing instructions are on the can ; Sea Foam has been on the market since 1942 and still carries a money back Guarantee !
With the price of Gasoline and Deisel almost $4.00 a gallon i hate to pour it out , you can get the same product in a spray can called Deep Creep i use both and i can tell you for a fact that this is the best fuel treatment i've ever used ; and well worth the cost for all it does !........
  #15
Old 06-04-2008 | 01:57 AM
redrider52's Avatar
wow that sounds like a great deal. i definateley need to look into that. thats perfect for me since i ride maybe once a month or less and then let my bike sit for long periods of time. thanks for the reply
  #16
Old 06-04-2008 | 02:43 AM
Baddawg's Avatar
I've never drained my fuel after using stabil,nothing in the directions
saying to.Says on the container "keeps stored gasoline fresh for quick starts"Would'nt be much good to me if I had to pour out the fuel.
  #17
Old 06-04-2008 | 04:51 PM
Williebee's Avatar
Baddawg Stabil will keep gas in a gas jug that hold's a gallon or more or the gas tank fresh for up to a year , it's the small amount of fuel that the carb hold's that must be drained ; Stabil treated fuel in small carb will beadup i know this for a fact because i ran a Small Engine Service and Repair shop from feb. 1977 untill i closed the shop in late 1997 !
I have a half of a case of Stabil leftover from 97' and i still use it in the lawn mower's , weedeater's and chain saw's during the growing season ; to keep this low grade fuel the Oil Companies are selling today from going bad !
I have a 1988 GMC S1500 Jimmy 4x4 MPV that i had to situp for almost 2 yrs. with a full tank of gas while i was saving the money to replace the timing chain and timing gear set , i used a full 16 oz can of Sea Foam in the fuel tank and had 2 of my brother's shake the Jimmy for 30 minute's to insure that it mixed good ; the Jimmy was smoking after it warmed up and i was planning to sell it as soon as i got it going again !
After i replaced the timing chain and gear set i had to drive the Jimmy while i was waiting on a freind to replace the seals in the transmission of my 87' S10 Tahoe Pickup , after i burned a half tank of the treated fuel the Jimmy stopped smoking ; there was carbon builtup in the combustion chamber causing the ring's to stick when the engiine got hot !
I would've taken a huge loss on the Jimmy if it hadn't been for the Sea Foam , it's been almost 2 yrs. ago and the Jimmy is still smoke free ; and it's my daily driver now !........
slowgsxr97
03-18-2022 04:40 AM
COFatboy
05-02-2020 01:06 AM
cody500ho
14
08-14-2015 06:03 PM
bpegram84
07-22-2015 09:15 AM
ghost civic
07-19-2015 11:13 AM
