WIll these tires and rims fit on my 95 trx 300 4x4?
Old May 8, 2008 | 07:21 PM
TheATVSuperStore.com's Avatar
Former Sponsor
Default WIll these tires and rims fit on my 95 trx 300 4x4?
Will these fit on the tank? Its a 95 trx 300 4x4. Fronts; 25x8x12 and the Rears are; 25x10x12 off a Big Bear.
Thanks,
Thor
Old May 8, 2008 | 07:40 PM
KNOWSALOT's Avatar
The Facility
I take it you are using the Big Bear wheels as well? It will all bolt right up to the 300. However, the 300 has different differential ratios in the front than it has in the rear and requires a shorter tire up front by 1". But most tires do ok if you run a couple pounds less in the front than the rear to make the ACTUAL diameters a difference of one inch.
If you don't pound the trails hard or ride often on hard packed surfaces, the difference in the ratios aren't going to make a dramatic impact on the ride, traction, or durability of the driveline. But if you do either,..it will.
Old May 8, 2008 | 07:54 PM
Former Sponsor
Thanks for the info.
fd24
Jan 16, 2019 08:59 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
cboler9
Sep 24, 2015 08:35 PM
