custom lift kit
Old May 8, 2008 | 08:31 PM
tancat500's Avatar
Default custom lift kit
I have an 06 ac 500 and i am looking to build my own custom lift kit for it. Does anyone have any suggestions, advice, or maybe personal experience they wouldn't mind sharing w/ me? Any help would be greatly appreciated! Thanks
Old May 10, 2008 | 01:54 AM
rango726's Avatar
i have heard many cases of the axles pulling out while riding do to lifts. i know a guy who messed up his atv good because his lift caused his axle to pull out. have you thought about bigger tires with polaris 800 shocks?? you will have to grind the eyelet to fit your frame but it will lift your atv. popo shocks are longer than the ones on our cats so when you mount them up at the angle our shocks are at you get a lift from it. and you get a nice ride too
Old May 12, 2008 | 12:36 AM
contentsunderpressur's Avatar
All you have to do is build some spacers for your shock mounts. Just don't go too big. Too much will break the cv joints or pull them out like rango said.
Old May 12, 2008 | 02:50 PM
swampyjunior's Avatar
Tancat,
You should look at somehighlifter HD springs for the front and rear. Kit with spring tool sells ontheir site for about $170 plus shipping. It added about 1.5inches of lift over the stock springs. Then get tires larger than 25inches say 26 or 27 inches.
Your steering will be improved with a good set of radial tires as the tires are less likely to roll on the rim and you get your lift. Plus as long as you don't go HUGE on the tires (30 or 31 inches) you will reduce the stress on your axles and bearings.
If you want to custom build something after doing this then customize the bumper and CV gaurds.
SJ
Old May 21, 2008 | 11:51 AM
tancat500's Avatar
Thanks guys for all the help! i made a set of spacers that moves the shock position by about one inch which is what i was told is about the distance the lifts you buy are.
Old May 22, 2008 | 10:04 PM
700 sportsman's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: rango726
i have heard many cases of the axles pulling out while riding do to lifts. i know a guy who messed up his atv good because his lift caused his axle to pull out. have you thought about bigger tires with polaris 800 shocks?? you will have to grind the eyelet to fit your frame but it will lift your atv. popo shocks are longer than the ones on our cats so when you mount them up at the angle our shocks are at you get a lift from it. and you get a nice ride too</end quote></div>
thats why you should buy a popo to start with
lol
Old May 23, 2008 | 01:27 AM
BirdDog4x4's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: tancat500
Thanks guys for all the help! i made a set of spacers that moves the shock position by about one inch which is what i was told is about the distance the lifts you buy are.</end quote></div>
I have been wanting to do the same with my 06 400 AC, just to give it a inch lift. You happen to have pictures of the spacers and the install! Thanks
Old May 23, 2008 | 06:58 PM
tancat500's Avatar
Hey BirdDog, I'll see what can do. It might be next week before ill be home to get those picks for ya!
Old May 24, 2008 | 12:53 AM
BirdDog4x4's Avatar
Not a problem on the pictures, but curious what you used to make them. Something you can get at your local hardware store and drill some holes?
Old May 24, 2008 | 08:30 AM
tancat500's Avatar
I used 1 1/4 square tubing and cut one side out of it. cut a piece 2" long cut one side out of it and drill your first hole about 3/8" in from end in the middle. from that hole drill another hole inch away. this will space your shock about one inch from the current location. you'll also have to get a piece of 3/8" pipe for a spacer on the current shock mount. then i cut a piece of 1/2 alu. drill some holes about 3" apart and drill a hole in the current shock bracket and mount the brace to the shock anf in the hole you drilled in the shock mount to keep it in the correct position. i know in sounds confusing, but ill try and get some picks to show you its really pretty simple!
