06 honda trx400 shifting problem
Old May 9, 2008 | 01:03 AM
djscopper's Avatar
Default 06 honda trx400 shifting problem
Have all 4 wheels off of ground will shift into gear but when you throttle on it grinds like it is not fully in gear thru all 5 gears. No codes flashing. Please help.
Old May 9, 2008 | 06:57 AM
HondaMechanic's Avatar
What does it do in reverse ..?
Old May 9, 2008 | 08:27 AM
djscopper's Avatar
It does the same thing in reverse go in gear wheels will move but when you throttle it up it starts making a grinding noise like it is not fully in gear
Old May 9, 2008 | 10:10 AM
Check the sub-transmission linkage/cable if they are ok then you should have the oil pressure tested in that bike...
Old May 9, 2008 | 08:35 PM
djscopper's Avatar
Oil pressure is good and the grinding seems to be coming from the back of the motor
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
sara durrant
Jul 6, 2015 05:32 PM
'86 TRX125
Jun 6, 2015 07:43 PM
