Big Bear Problems
Old May 9, 2008 | 05:45 AM
jkoss42's Avatar
Default Big Bear Problems
I have a 98 Big Bear 4x4 thats sat in my shop for a while. The other day I put a starter on it and the engine wouldnt turn over. I pulled the side cover off and tried turning it over by hand. The engine will rotate counterclockwise not the other. I push started it with another 4wheeler and it fired right up. My question is way wont the engine rotate both ways when I try to rotate it. Thanks for any advice because this has got me baffled.
Old May 9, 2008 | 11:49 AM
pmcc37's Avatar
have you tried it since you push started it, and was it in gear?
Old May 10, 2008 | 01:50 AM
jkoss42's Avatar
Yeah I tried it again since I push started it and the same thing. Engine will only rotate one way with it in neutral or in gear
Old May 12, 2008 | 09:29 AM
pmcc37's Avatar
something isn't right, but not quite sure, if it will start(pull starting, sounds like something is in a bind...
skinnyr6
Aug 25, 2023 02:18 AM
Ean
Dec 19, 2022 08:48 AM
clsharky
Jul 13, 2015 02:07 PM
cornermike
Jul 8, 2015 11:44 PM
honda71
Jul 8, 2015 02:13 AM
