What causes compression thats too high?
Old May 12, 2008 | 05:22 PM
BigRay660R's Avatar
Default What causes compression thats too high?
I have taken then cam out. Inspected decompression and it works good. Lashed the valves, but my starting compression is still so high that i can only turn it over about 10 times very slowly (too slow to start) before the brand new battery pukes. Its eaten 2 solenoids from the high current draw. Have u guys seen a chain jump on the cam or crank gear? What would be the cause?
Old May 19, 2008 | 01:02 AM
TomM's Avatar
Hard to believe it runs down a fully charged battery in 10 seconds. Seems more likely you have a bad connection somewhere and the starter just barely gets enough to spin it under ideal conditions but doesnt after you pull a ton of current for 10 seconds. What kind of quad? Can you pull the plug out and spin the motor manually to see if there is really physical resistance there?
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
bvolks
Sep 13, 2015 12:57 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
