1988 trail boss 250 will not start
Old May 15, 2008 | 10:15 PM
Hells Ranger's Avatar
Default 1988 trail boss 250 will not start
Hello, my 88' polaris trail boss will not start, it is getting fuel because if i remove the plug i can ignite the fuel in the chamber, ive tried using choke, and "pumping" the throttle. Also i seem to have a pretty weak spark Although ive never seen spark on an ATV before only on cars. It almost seems like the spark isnt enough to ignite the fuel and start the engine. If i remove the plug and spray in some starter fluid it will start and run. But will not start otherwise. Any help would be appreciated
Old May 15, 2008 | 10:34 PM
drlang's Avatar
Do a compression check, hope fully you'll be above 110psi. Doc
Old May 15, 2008 | 10:38 PM
yea i was getting 110-115psi compression. I also forgot to mention this was bored out and is now a 310cc i believe. IDK if that has anything to do with it. But if it was my guess its somthing to do with the ignition the spark is so weak, that it almost has to be dark to see it.
wildbill59
Jun 20, 2015 02:26 PM
1000gade
May 27, 2015 12:37 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
