axle nuts
Old May 16, 2008 | 10:00 AM
97 RAT's Avatar
Default axle nuts
is there a trick to getting axle nuts off? i replacing the sprocket hub on my warrior and i cannot even budge the axle nuts. its the last thing i need to do to get my $400 warrior on the trails.
let me know your secrets...
Old May 16, 2008 | 11:24 AM
ATV_MAN's Avatar
Default axle nuts
the nuts on the wheel hubs? Make sure the cotter pins are off and lube up the nuts, I would not heat them, this can weaken them. Use a breaker bar with a pipe on the end for more leverage.
Old May 16, 2008 | 01:48 PM
StngGT350's Avatar
Default axle nuts
if you are talking of lug nuts and if they are stipped. well this always worked for me. i get a thick grease wrag and put over the stripped lug and happer on the correct size socket and slowly use a breaker bar to get it off. if you are talking about on teh wheel hubs, well ATV_MAN is right on, i would do what he said.
Old May 16, 2008 | 10:25 PM
97 RAT's Avatar
Default axle nuts
not the wheel nuts but the jam nuts that are on the axle holding the sprocket on.
Old May 16, 2008 | 11:47 PM
Raptor450's Avatar
Default axle nuts
I use 2 big pipe wrenches that are about 2 feet long each - 1 for each nut.
Old May 21, 2008 | 03:40 AM
DS650ryder's Avatar
Default axle nuts
i went down to my local cheap, 1 time use, tool store (harbor freight) and got a like i wanna say 24-30in crescent wrench for like 10 bucks and it got my banshee nuts right off = ]
Old May 24, 2008 | 10:00 PM
2Owanage's Avatar
Default axle nuts
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
I use 2 big pipe wrenches that are about 2 feet long each - 1 for each nut.</end quote></div>
I also used this method and it worked great for me
Old May 24, 2008 | 10:33 PM
91Warrior357's Avatar
Default axle nuts
i useda toothbrush and teezers, lol nah u just gotta take the cotter pins out of the castlenuts, soak it in PB blaster and slip a pipe over big cresent wrench or pipe wrench or wutever and give it a few tugs, lol i hope u didnt already pull the wheels off and lifted it in air tho becuz it will be harder then
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
raman8tor
Sep 20, 2015 07:35 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
