axle nuts
is there a trick to getting axle nuts off? i replacing the sprocket hub on my warrior and i cannot even budge the axle nuts. its the last thing i need to do to get my $400 warrior on the trails.
let me know your secrets...
if you are talking of lug nuts and if they are stipped. well this always worked for me. i get a thick grease wrag and put over the stripped lug and happer on the correct size socket and slowly use a breaker bar to get it off. if you are talking about on teh wheel hubs, well ATV_MAN is right on, i would do what he said.
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
I use 2 big pipe wrenches that are about 2 feet long each - 1 for each nut.</end quote></div>
I also used this method and it worked great for me
i useda toothbrush and teezers, lol nah u just gotta take the cotter pins out of the castlenuts, soak it in PB blaster and slip a pipe over big cresent wrench or pipe wrench or wutever and give it a few tugs, lol i hope u didnt already pull the wheels off and lifted it in air tho becuz it will be harder then
