Snorkel for Honda Foreman 450
Old May 16, 2008 | 09:02 PM
StrikeTheBox's Avatar
Default Snorkel for Honda Foreman 450
I'm curious to those who have installed the snorkels on their rides... specifically the one from Triangle ATV (http://www.triangleatv.com/products.html)
Pretty much, I'm not very mechanically inclined... how hard was this to install?
Old May 16, 2008 | 09:47 PM
Nemesys67's Avatar
I dont think they are very hard to install. Talk to Jrafter....He made his own I believe. Looked good too.
Old May 16, 2008 | 09:51 PM
Nemesys67's Avatar
Found the post.
http://forums.atvconnection.co...atid/8/threadid/542168
Old May 17, 2008 | 08:02 AM
jrafter's Avatar
the kits you can buy are nice put there your over priced and you can make your own for less the $20
Old May 18, 2008 | 07:45 AM
contentsunderpressur's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jrafter
the kits you can buy are nice put there your over priced and you can make your own for less the $20</end quote></div>
+1000 I looked at the prices on those store bought snorkles and they are outrageous! Just buy some pipe and do it yourself.
Old May 18, 2008 | 07:52 AM
jrafter's Avatar
thats why theres no return on it once you buy it.....because they know you can copy it
Old May 18, 2008 | 01:31 PM
thanks for the info!
does anyone have a do-it-yourself guide made up for the snorkel? that would be a good item to put up on ebay or something for a couple bucks if it can save $100 on buying a manufactured one.
Old May 18, 2008 | 01:39 PM
The easiest thing to do is to use spa hose. Then you just remove the stock snorkle and put a pvc fitting in there and clamp it down. Glue the spa hose in and run it where you want it.
Old May 18, 2008 | 02:41 PM
jrafter's Avatar
i would start off by pulling the stock snorkel than that will yell you everything you need.........it aint hard once you get the stock snorkel out you will see how much room you have to work with .
it all depend on which side you going to run it on after that.
a 10' peice of ABS pipe and 4 90s and go from there
Old May 18, 2008 | 02:58 PM
thanks for the help... i'll let you know how i make out!
