Oil Injector and Water
Old Jan 21, 2001 | 11:30 PM
KevinDevitt's Avatar
I adjusted my throttle cable (slack) and ETC today. BTW I highly recommend that if you have not done this you should. As per the manual it recommended that you check the adjustment on the oil injector. I pulled the 3 screws holding the plate on and about a half cup of water flowed out and onto the ground. The last ride did involve some deep water. I also power spray my quad after most rides. The water was clean. It was kinda gunked up on the bottom of the oil injector interior housing. I cleaned it up best I could and put a trouble light in front of it to dry it best that I could. The rubber gasket looked fine. Has anyone seen this before? Did it cause me any problems that I might not be aware of.
Thanks for any help.
KD
Old Jan 22, 2001 | 09:37 AM
Farmr123's Avatar
As they say, it happens. In the winter it can cause a frozen throttle.
As far as I know, it shouldn't hurt anything. Dry it out really good & douse it with WD-40 or something similar to keep anything from rusting. Be careful not to spray the injector directly with a power washer. Even if the gasket is good, it is only designed to keep water out when crossing a puddle, not water under pressure.
Old Jan 22, 2001 | 10:41 AM
Good idea on spraying it with WD40. I will take it back apart and do that.
Thanks
KD
Old Jan 22, 2001 | 01:22 PM
Dazed's Avatar
There is a small hole in the bottom of the oil pump housing sounds like yours is pluged open it up so it can drain It is a real smaall hole so you will have to look for it.
Old Jan 22, 2001 | 02:37 PM
Thanks!!!!
I just love this place so much good info.
KD
Old Jan 22, 2001 | 11:55 PM
Dazed:
Call me blind but I could find no drain hole. I looked and looked (even used a mirror). I went ahead and sprayed WD40 and put it back together. Are you sure there is a hole?
Thanks KD
Old Jan 23, 2001 | 04:12 AM
Dazed's Avatar
Yes iam i was showed it by a technical service man at polaris last fall when my 99 400 scram filled with water and debris. It is a real small hole.
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
craacker
Sep 9, 2015 04:32 AM
