2007 800 EFI
I have a 2007 800 EFI with low miles. I have owned Polaris machines before and have never expierenced this issue before and not sure if there is even a problem. When I shift the machine into reverse there is a slight noise as I give it some gas then it feels like it goes right into reverse. Is this common or do I need to get it fixed?
Mine makes a clunk sometimes, like when I shift it from L to R or R to L. Seems like the gears don't mesh sometimes unless you give it some gas to get the driven clutch moving slightly.
I haven't bothered to take it in. If it clunks when I shift it then I know everything is engaged. If it doesn't clunk, I just go very easy on the gas until it does, or rock the ATV back and forth once and that will get it to engage.
Good luck.
Good luck.
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
