Sport Quads Discussions on sport quads.
paddles
Old May 19, 2008 | 06:38 PM
the-chick's Avatar
Default paddles
for a 400 ex what paddle to go with any suggestions. the machine is mainly stock except for a 13 tooth sprocket kn airfilter and white bros pipe.
Old May 19, 2008 | 06:43 PM
-Gary-'s Avatar
Default paddles
<div class="FTQUOTE"><begin quote>Originally posted by: the-chick
for a 400 ex what paddle to go with any suggestions. the machine is mainly stock except for a 13 tooth sprocket kn airfilter and white bros pipe.</end quote></div>
For drag racing - straight paddles (8 paddles)
For dune riding - ITP Sand Stars. Hook up well and let you roost and slide as you want.
Old May 20, 2008 | 10:18 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default paddles
I like the buffed down Skat-Trak's. They are way lighter than the new generation of molded paddle tires...and weight is your enemy in the sand!
For my lightly moded EX, I run 6-Paddle Skat-Trak Edges (V-shaped paddle) on the back, and Skat-Trak Mohawks on the front.
Depends on where you ride, whether you want to pick the the V-shaped paddle or the straight ones. I like the V, because they allow quicker turning, so they are my choice for Oregon Dunes, Glamis, and Dumont. If you just ride one of the "sand box" areas where drag racing is all there is to do, then the straight paddles might serve you best.
Old May 20, 2008 | 11:28 AM
-Gary-'s Avatar
Default paddles
wrong reply
Old May 20, 2008 | 11:56 AM
Red Rider
Default paddles
<div class="FTQUOTE"><begin quote>Originally posted by: -Gary-
I lost my internet connection after I hot "submit" and may have lost me little writeup on weight, but it's worth noting that the 700XX is only 50 pounds heavier than a 700r with fluids. The dry weight thing is retarded and I'm glad manufacturers are starting to report weight for what it is "ready to ride".</end quote></div>
Your post ended up in the wrong forum!
Old May 20, 2008 | 12:56 PM
-Gary-'s Avatar
Default paddles
<div class="FTQUOTE"><begin quote>Originally posted by: reconranger
Your post ended up in the wrong forum!</end quote></div>
Right, I deleted it a good while before you posted this.
Old May 21, 2008 | 01:59 AM
bigned1904's Avatar
Default paddles
i think a 8 cup hauler would be way to much for your quad. i would get some 6 or 8 cup skat trak gliders for yours. and no madder what kind of paddle to get make sure it is a skat trak. they are the lightest and imo the best paddles made.
but if you are on a budget and dont want to spend alot of $ get itp sand stars on 8 inch rims
Old May 21, 2008 | 06:35 PM
YFZsandFreak's Avatar
Default paddles
skat trak glider 6 paddles you will not be dissapointed!! perfect for the 400's
Old May 27, 2008 | 05:03 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Default paddles
Agreed, 6 or 8 paddle gliders would be just fine for you
Old May 27, 2008 | 08:25 PM
bigned1904's Avatar
Default paddles
sometimes gliders are better even for high hp quads. i herd 2 guys said they picked up 3 lenghs up a hill last weekend by going with 10 cup gliders over 10 cup hauler because the sand was wet. and these guys are making big power. like 75-80hp
