70 hp 800 RZR / SP
Old May 21, 2008 | 01:15 PM
Speedwerx's Avatar
Default 70 hp 800 RZR / SP
We have benn hard at it on the dyno for about 2 weeks now and have a pretty soild package that has been working very well. We have over 150 runs at this time too.
Right now we are getting 69-70 hp at the crank @ 6900-7000 rpm. These #'s are on a good hot motor with back to back to back runs to ensure info is accurate.
Current package includes:
Hsp full ex.
Hsp high flow intake
Hsp cam kit with .010" head gasket to bump compression
Hsp Stage 3 head porting
Hsp ecu remapping
Boondocker fuel controller
We are testing more head work, pistons and ecu stuff as we speak I will post if we find any more info.
Old May 21, 2008 | 01:17 PM
user493's Avatar
Moto Psycho
Sounds great. Are the new catalogs out yet?
Old May 21, 2008 | 05:53 PM
Speedwerx's Avatar
You can print the new one off of the site, we will not have printed versions in our hands for a week or so.
Old May 21, 2008 | 06:32 PM
SPORTSMAN70003's Avatar
Hey speedwerx have you done anything to the bottom end like a stouter crankshaft? How much HP do you think the stock crankshaft can handle?
Old May 21, 2008 | 06:53 PM
Speedwerx's Avatar
Depend's on what rpm you want to spin, there is more power at higher rpm's but for consumer we do not suggest going over 7000 rpm right now.
We do offer a pin / weld on the 700 / 800 cranks for durability reasons. We normally on do this on our race motors that will run @ 7000 rpm or higher all day long.
To date we have not seen any failures on the dyno or in the feild.
I will say that it is more of an rpm issue than a hp issue if the crank is to fail the stock design is not the best but it is working ok for now. I've heard of other's working on custom cranks but I'm sure they will be $$$$$$.
stendori's Avatar
Super Quad Patrol
I'm watching you!
and whats the price tag for all the updates goodies?
Old May 21, 2008 | 07:02 PM
<div class="FTQUOTE"><begin quote>Originally posted by: Speedwerx
I will say that it is more of an rpm issue than a hp issue if the crank is to fail the stock design is not the best but it is working ok for now. I've heard of other's working on custom cranks but I'm sure they will be $$$$$$.</end quote></div>
Where can I purchase the pin / weld for the crank? Can the limiter be raised to 7000 on the 03 700?
Old May 22, 2008 | 10:38 AM
Speedwerx's Avatar
Stendori, These are prices for each of the parts.
Hsp full ex. Should be about $ 595.00
Hsp high flow intake $ 39.95 on Rzr more mods to come maybe more ?
Hsp cam kit with .010" head gasket to bump compression $ 328.74
Hsp Stage 3 head porting $ 1299.00
Hsp ecu remapping $ 399.95
Boondocker fuel controller $ 418.00
Crank pinning $ 300.00
If you have any more ?'s please let us know.
Old May 22, 2008 | 10:39 AM
Speedwerx's Avatar
Sportsman70003, we cannot remap the carbed cdi's to raise the rev limiter. The crank pinning is 300.00 your crank will need to be sent to us to have it done and right now there is only about a week or 2 turn around.
