false confidence...sunken atv..
Old May 23, 2008 | 09:31 PM
holters's Avatar
Default false confidence...sunken atv..
so i recent.ly got new tires and rims for my 03 kodiak 400...a deep spot in the river later and im floating and stalling out..... needless to say.. two days later and i still cant get it to start... air box, is clean filter clean, water is drained(so i think) and spark plug is good.... what am I missing? it tries to start just wont turn over... any help is appreciated
Old May 23, 2008 | 09:44 PM
papahouse's Avatar
remove the spark plug and try to crank it, I'm thinking you have water in the cylinder. Once the water is out replace the spark plug and it should start
Old May 23, 2008 | 09:47 PM
faponce's Avatar
I sank a Honda once we drained the bowl on the carb, change the oil and filter, new plug and put a bottle of HEET in the gas tank it fired right up.
Old May 23, 2008 | 11:00 PM
91Warrior357's Avatar
change oil twice,dry out filter, new gas with Heet, drain fuel bowl, make sure your electrcal connections are all dry, make sure no water is in your pipe,and your cylinder,new sparkplug and it should be good, buddy of mine had same prob, lol we pulled the head pipe off his blaster and we just poured out water after water and kicked it until water was all out then it fired up lmfao
Old May 24, 2008 | 05:21 PM
faponce's Avatar
Good point I forgot we stood it up on end and drained about a gallon from the pipe.
DOA
Apr 26, 2004 08:58 AM
Hayseed
Jan 3, 2004 06:53 PM
RaptorRider247
Jun 4, 2002 01:40 AM
